Loss of Boost
Old Apr 11, 2014 | 02:09 PM
Dieselhead6.5's Avatar
Default Loss of Boost
Just seein if anyone has some ideas before I start throwin parts at this thing, My 95 6.5 vin F runs great when its cold, but when it warms up and I get in to the throttle and the boost hits 10psi it immediately drops to 0psi and the truck just blows black smoke until either I coast for a bit or stop then it will build boost again as long as I keep it under 10 psi.
(new relocated PMD, New vac pump, strait piped, very little play in turbo, EGT runs aboet 400-450 deg.)
Old Apr 13, 2014 | 10:51 AM
racer55's Avatar
Boost solenoid is likely gummed up and when commanded to vent keeps doing so,spray some WD40 in the vac ports of the solenoid or replace it with AC Delco.
Would also be a good idea to check and clear the trouble codes.
google paper clip trouble code test.
kalarachelle
Feb 21, 2015 03:25 AM
stewart.william.c
Feb 11, 2015 01:39 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
offroad00
24
Oct 23, 2014 03:28 PM
