Super b special
Old Apr 10, 2014 | 05:31 AM
dieseldemon61's Avatar
Default Super b special
So I just got my new turbo yesterday, but I'm a little surprised in the amount of shaft side to side play in it. Should I be concerned?
I'd share a video of it but I don't thinks it will let me
Last edited by dieseldemon61; Apr 10, 2014 at 05:31 AM. Reason: Automerged Doublepost
Old Apr 10, 2014 | 11:12 AM
94 12valve's Avatar
all new chargers will have side to side and very little in and out play. After some oil is ran through it it will tighten up a little bit. With the shaft thrusted to either side if the comp wheel does not hit the housing it will be just fine. The in and out play is really what your going to want to watch.
Remember before you put the oil feed line on add some oil into the trubo.
Old Apr 10, 2014 | 11:43 AM
12vcummins96's Avatar
dave is right on
Old Apr 10, 2014 | 06:10 PM
turbo2332's Avatar
s300's are remarcably loose compared to other chargers. it is fine.
Old Apr 10, 2014 | 06:48 PM
Ok thanks fellas, as soon as I get my manifold next week I'll be putting this turbo on.
Old May 2, 2014 | 07:52 PM
4x4manonbroke's Avatar
So, hows the turbo treatin ya ???
Old May 2, 2014 | 07:57 PM
So far it's great! It's a little laggy at bottom end but my afc needs re-adjusted so it could because of that
Old May 4, 2014 | 03:50 PM
Awesome , apply more star wheel to get some low end velocity out of it , back off the smoke screw if its too smokey ... should be awesome !! viedo and pics would be awesome too
Old May 4, 2014 | 04:57 PM
Yea the smoke screw needs backed out a good bit, I'm in the process of getting a pressure/vacuum tester so once I get that I'm going to set the afc to full fuel at 15psi. I'm not even sure where the star wheel was set at when the pump was benched.
Old May 4, 2014 | 06:12 PM
probably tight .... loosen a bit .... i left out the plug for the wheel ... found a quiet back road ... i just tuned till it was awesome ..
