turbo time
Old Apr 2, 2014 | 09:04 PM
bhackl's Avatar
Default Turbo upgrade?
looking to upgrade turbo.. and trying to find out whats best to go with for my application.. I have an 01 cummins 2500 six speed. So far I have quadzilla programmer, 120hp injectors, air dog 150, intake and horn.. I do tow with this truck and use it at my job so i need something to work well with that.. i have looked into compound turbos but also looking into single.. whats everyone thing is best.. any help would be greatly appreciated..
Old Apr 14, 2014 | 12:20 PM
Smarty=Cummins's Avatar
A 63-68-14 is a good turbo for my truck I hit 50 pounds of boost and egts are a little high but not bad. I got my turbo from torque diesel very good people.
Old Apr 15, 2014 | 08:45 AM
jkidd's Avatar
We have the 63/68 in a T3 hx40 14 non gated for under $1000, 12cm gated is also available. A 60/68/14 may be a better option since you only have 120hp injectors. with a 63/68 you should be able to support low-mid 500HP and could go up to 175HP.
Old Apr 18, 2014 | 05:06 PM
jigabop's Avatar
really depends on your power goal.
I personally run 6x.013s with 357 over 475 compounds and daily drive it.
it does haze and puffs a little smoke if you don't baby the throttle, but it is very snappy and responsive. egt's stay well under control.
for a rig that tows twins wiht some 7x.012s should be quite a bit cleaner at idle and under acceleration and be very powerful
definitely hit up jacob for your turbo's
he's a great guy to deal with!
I bought my turbos, twin plumbing, intercooler boots, some of my gauges, boost bolt, clutch, etc from jacob
injectors from weston, fuel module from jamie.
Old Apr 26, 2014 | 12:53 PM
noseamum's Avatar
I would/will go for a 57/65/12 over a S400 or a Htb3.So it spins up fast.
As the 57/65/14(SuperB) I have now spins up 400rpm later than the hx35(56/65/12?)which I think is significant with the 6speed I also have in my truck.
With the hx I had 15psi at 1000rpm, with the SuperB I have 5-6psi at 1000rpm.
Hx(32psi) fully spooled at 12-1300rpm, superB(45psi)at 16-1700rpm, so I think the smaller exhaust housing and compound will be best.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
sak240
Oct 1, 2015 04:07 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
