Passenger Vehicles General Discussion General Diesel Discussion of all Passenger Vehicles with Diesel Engines
Turbo Boost Without Intercooler
Old Apr 24, 2008 | 04:13 PM
lancerevodiesel's Avatar
Default Turbo Boost Without Intercooler
Hi
I have a 1990 Mitsubishi Lancer 1.8 turbo diesel 4d65-t with a td04-09b turbo. I was wondering how much safe boost as standard I can boost without intercooler. Right now I am getting 9-10 psi. Is it safe? And how can I set the fuel pump to have minimum black smoke please.
Thanks!
Old Apr 24, 2008 | 04:29 PM
DangerousDuramax's Avatar
Thats a good question. Maybe our resident TDI expert can answer this. Oh TYE?
Old Apr 24, 2008 | 04:37 PM
Benjamin's Avatar
Bombardier
you are prolly looking to be safe at 6-7psi with a non intercooled setup..... what turbo do you have? if larger than stock, like a TD04 you might be able to safely get a couple of more pounds out of it but you are playing with borrowed time on the head gasket.
Old Apr 24, 2008 | 04:38 PM
Buckshotmckee's Avatar
Sma't Alec!
What year is it?
Old Apr 24, 2008 | 04:42 PM
Benjamin's Avatar
Bombardier
Isn't it a 1990 model 4d65 series motor?
Old Apr 24, 2008 | 04:59 PM
Sma't Alec!
I just called my buddy who is/used to be a Mits tech and he said 4-6psi is about the max. Anything more and the heads gonna let loose. Hope this helps.
Old Apr 25, 2008 | 01:27 PM
Yes, it's a 1990 4d65. The turbo is a TD04-09 and was added recently, maybe a year! Minimum boost is 8-9 psi with the least wastegate rod tension. I can't reduce the boost pressure. Is there another way to reduce pressure?
Thanks for all of your replies.
Old Apr 25, 2008 | 03:03 PM
Sma't Alec!
Got any pics of the wastegate? Can you change or make your own rod for the wastegate to give you more adjustment?
Old Apr 25, 2008 | 04:45 PM
I can set it to have more boost off course. But i want to reduce the boost to 7 psi approx.
Old Jun 22, 2008 | 06:25 PM
But how can i set it to 6 psi, with the minimum possible setting of 9 psi?
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
Tsgbk9
Dec 23, 2014 11:54 AM
offroad00
24
Oct 23, 2014 03:28 PM
GreenDieselF
Oct 20, 2014 02:05 PM
