s363
Old Mar 25, 2014 | 12:45 AM
mrmuddy76's Avatar
Default s363
Hey yall. so im looking at getting a new charger for my 05. I was looking into getting a
htt s363 with a .91 divided housing. I know I will need a t4 manifold but what else is necessary to fit on of these to my truck. I wouldn't mind even going to a 2nd gen manifold but I was told that a s300 would clamp directly to my down pipe if I use the he 351 elbow. looking for people have done this and know what to expect. let me know what u think
Old Mar 25, 2014 | 10:23 AM
crf450x's Avatar
Box BW chargers have a marmon dp flange. You can get an he351-marmon adapter though. You'll also need to drill out the bolt holes on the oil return line to 3/8. And you'll need a wastegate fooler. Swapping to a 2nd gen manifold is a whole different project...
Old Mar 25, 2014 | 11:14 AM
mrmuddy76's Avatar
Please forgive my ignorance... But the searching I have done and looking turns up that a hx40 dp might be the same and the marmon. Also the 2nd gen manifold swap would just involve a manifold and a charge air pipe correct. And then move the oil return line.
Sent from my HTC6435LVW using Tapatalk
Old Mar 25, 2014 | 11:37 AM
crf450x's Avatar
No but you can have the housing machined to an hx40 flange. To do a 2nd gen swap in stock position you need a 21" oil return, intake, down pipe, and manifold. The stock intercooler piping will work. Just have to twist it around and cut a little off the end.
Old Mar 26, 2014 | 09:50 PM
mrmuddy76's Avatar
What do u think about running the s363 with a .91 divided housing. I know that u can run a lot smaller housing if u have it gated. I'm worried bout that .91 being hard to spool
Old Mar 27, 2014 | 09:54 AM
crf450x's Avatar
The .91 housing is definitely what you want. It spools just fine imo. And there is no need for a gate unless you have bigger than 100hp injectors and don't want to just pull a little fuel out.
Old Dec 8, 2014 | 04:32 PM
FlyingDutcman's Avatar
not too hijack this thread or anything, but muddy if you buy a new turbo you wanna sell me that 351?
CGME
Mar 5, 2015 09:30 AM
