EBPV removal question
Old Mar 16, 2014 | 08:24 PM
Dieselhead1052's Avatar
Default EBPV removal question
I've been reading up on EBPV removal. I know how to do all of it except for how to deal with eliminating the EBP sensor and the soft codes that follow. When I get my exhaust in the mail this week i'm going to remove my turbo and install the non-EBPV pedestal, but not if i'm going to be throwing codes. There are some companies that sell sensor delete plugs but say there may still be a low pressure code. Unacceptable. Help?
Old Mar 16, 2014 | 11:40 PM
joebob3093's Avatar
Moderator
I just unplugged mine
Old Mar 17, 2014 | 05:46 AM
autostroker's Avatar
Mine is just unplugged. Might throw a soft code, but does not make check engine light come on.
Sent from my SCH-R970 using Tapatalk
Old Mar 17, 2014 | 08:31 AM
MAFoElffen's Avatar
I had had a frozen/stuck EBP Valve. After that, even after reopenning it, it wanted to occasionally stick, so I unplugged it and ran like that for quite a while before I did a pedestal EBPR and the turbine outlet EBPV delete.
At first I was going to keep the valve, repurposed as an exhaust brake, (EBP and clutch rewire, with switches and relays). But I kept hearing that there was more harm that benefit in doing that, heard how hard that is on transmissions and was still having that occasional sticking problem so I completely deleted it,.. to include using an electrical bypass plug for the EBPR.
BUT-- I kept the EBP Sensor installed. It does more good than harm there. It adjusts the fuel tables when cold and I use it in Torque Gauges --> EBP PSI and EBP/Boost driven ratio... But have many friends that deleted that also and there was no matter to them.
Joracing3
Sep 10, 2016 05:28 PM
Josh_L
Apr 12, 2015 12:12 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
OBSBEN
Jan 8, 2015 08:21 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
