Add a leaf question
Old Mar 8, 2014 | 12:19 PM
Dillon121's Avatar
Default Add a leaf question
I am looking to level the front of my 94 f250(regular cab 4x4) with the rear.
Should I be looking at the 1.5" or 2"?
Thanks for the help!
I just measured from the ground to the top of the wheel well, got a little under 39" in the rear, and around 36" in the front.
I'm thinking now maybe 3".. Any ideas?
Old Mar 8, 2014 | 05:59 PM
4x4manonbroke's Avatar
I did the 2" lift and with all the weight my front end is 1/4" lower than the rear still ... and i clear 315/75/16 with no rubbing anywhere
Old Mar 8, 2014 | 09:48 PM
Sycostang67's Avatar
I got the 2" AAL and ended up 3.25" higher, they will settle a bit over time, but not much.
Old Mar 9, 2014 | 01:50 AM
powerstrokin350's Avatar
I'm not positive, but you might not want to trust the wheel well measurement. The wells could be "cut" into the body different depths. I would maybe go to the bottom of the body right behind the front wheel well and right in front of the rear wheel well. I think a 3" would probably give you a nose up look. I'd ask a 4X shop, they'd help with leveling kits, or if you want to lift it all the way around.
BGbowhunter
Jun 20, 2015 10:17 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
2FordStrokers
Tire, Wheel & Suspension
Jan 5, 2015 09:23 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
Sep 29, 2014 03:00 PM
