IDI IP pump tuning help
Old Mar 7, 2014 | 10:37 PM
91 7three's Avatar
Default IDI IP pump tuning help
I went to turn my injection pump up on my IDI and i can't get it to turn. I feel like if I push any harder it's gonna snap somethin. Is it common to be pretty tough to turn?
Old Mar 8, 2014 | 11:46 AM
Dortiz's Avatar
Are you talking about the timing? You need to loosen the 3 9/16 nuts holding the pump to the oil filler, then with a 3/4 wrench I believe that's the size. You can place it onto the square notch on the front of the pump, and turn it either way. Yes it can get tough to turn, but please be careful.
Old Mar 8, 2014 | 04:03 PM
91 7three's Avatar
No the fuel screw. It wouldn't turn either way and it stripped out so I can't turn it now. I'll wait till I get a new pump
Old Mar 8, 2014 | 06:01 PM
4x4manonbroke's Avatar
should turn easy .... unless someone has modded the pump and made it non-adjustable some how ....
Old Mar 8, 2014 | 06:27 PM
Dortiz's Avatar
I know with mine, It does not turn easily. I had to bend the end of a key into a loop, now I just stick a screw driver in and easier than pie
Old Mar 8, 2014 | 07:50 PM
91 7three's Avatar
I'll see what else I can do. Pretty sure I stripped it
Old Mar 8, 2014 | 09:46 PM
Sycostang67's Avatar
If you couldn't turn it, someone else may have maxed it out. Over tightening it can damage the pump internals. If it's maxed out and you aren't getting any smoke(not promoting it) out of it, the pump itself may be tired.
Old Mar 9, 2014 | 02:15 PM
91 7three's Avatar
That's probably what happened then. I'm sure it's tired, it's got 180k on it. I'll just have to get it rebuilt
Old Apr 30, 2014 | 01:47 PM
trh161's Avatar
when i turned up mine it is really are i took off the ats intake to get my room and i used a 5/16 and a crescent wrench and it took me some time to get it to turn but it will i promise
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
359ci12v
Apr 9, 2015 08:24 AM
moneypitk5
Feb 12, 2015 11:01 AM
Tower crane guy
Oct 22, 2014 06:04 PM
