6.2L needs help
Old Apr 21, 2008 | 08:41 AM
redstroker_2002's Avatar
Default 6.2L needs help
I got a 85 gmc with the 6.2 diesel in it! It has a hard time getting fired up in the morning. it doesnt matter if its warm or cold starting fluid has to be used! also it will start and run for about 20 seconds and then it sounds like it ran out of fuel. so is it something with the fuel filter housing? also it seems to idle really rough lately and it will die sometimes! i need help with reliability this truck is a storm chaser and i dont want it to break in the path of a storm!
Old Apr 21, 2008 | 11:42 AM
greasemonkey's Avatar
you could always try a 4BT!
Old Apr 21, 2008 | 01:01 PM
jdugie123's Avatar
my friends old 6.2 did the same thing he had a cracked fuel filter housing that was allowing air into the lines we replaced that and haven't had a problem since
Old Apr 21, 2008 | 03:05 PM
thanks hopefully she will be running good for the storm season!
Old Apr 21, 2008 | 08:49 PM
wildbill's Avatar
Fuel pump probably isn't doing so hot either, along w/ rotten fuel lines.
Old Apr 21, 2008 | 09:03 PM
jdugie123's Avatar
but doesn't the 6.2 have a mechanical fuel pump i don't think it is electric my friends sub has over 300k on it and the only things that have gone wrong is they had to replace the TCM and the fuel filter housing because of the crack
Old Apr 21, 2008 | 09:10 PM
wildbill's Avatar
Mechanical all right. They do lose prime to.
Old Jul 14, 2008 | 04:02 PM
wildbill's Avatar
Problem fixed?
Old Jul 14, 2008 | 09:26 PM
LOGANSTANFORTH's Avatar
you need more help than the truck does......i would have something a little faster than a 6.2...........
RatsMC
May 4, 2015 05:25 PM
letters4and18
Mar 25, 2015 03:06 PM
