bad cummins ecm
Old Feb 13, 2014 | 10:00 AM
lilmike1540's Avatar
Default bad cummins ecm
So i think my ecm in my 01 is bad the truck bucks like mad at idle with tons of white smoke some times it will idle nice when it gets warmed up but it wont rev past 1200 rpm in gear but if you put it in park it will rev all the way you can hear the motor change in sound as well like the vp44 is pushing more fuel through it and then goes away and comes back i havnt hot wired the pump yet but was wanting some ideas do you thing i could fix it with a tuner if that is the issue what you guys thing ???
Old Feb 13, 2014 | 12:47 PM
mysterync's Avatar
How did you come to the email conclusion? A chip won't fix mechanical issues. Sounds like a dying vp. Got good fuel pressure?
Sent from my SCH-I605 using Tapatalk 2
Old Feb 13, 2014 | 12:55 PM
Fuel is at 16psi and a tech at blue chip diesel said it sounded like a ecm but i wanted to get some more ideas is there any way they bolth could go out
Old Feb 13, 2014 | 01:36 PM
mysterync's Avatar
I guess my question is why? What reasoning? We don't replace parts because it "sounds like it". We replace parts because data directs us too that component. My question is what data do you have that has suggested a faulty ecm? Have powers and grounds been tested at the pump? I see you haven't done a stand alone, that's a for sure way to eliminate the ecm from the list of possibilities. What about the apps, has it been checked?
Old Feb 13, 2014 | 02:05 PM
i also replaced the apps i did forget to say that when i swap out the relay for the fuel it rain good for about 10 minutes then did the same crap
the reason i was wondering about the tuner is that if the ecm has a bug would flashing it with a tuner would it fix the bug
Last edited by lilmike1540; Feb 13, 2014 at 02:05 PM. Reason: Automerged Doublepost
Old Feb 13, 2014 | 02:18 PM
mysterync's Avatar
No a malfunction of that nature is not related to ecm software. That relay might give you some direction. Maybe check powers and grounds at the ecm, Pcm, and vp-44. Wouldn't dare replace my ecm unless I had reason and proof. Standalone the pump then make a decision!
Old Feb 13, 2014 | 02:28 PM
ok is there any specific place to check for sure like a problem area for that type of truck? and from the sounds of it your beting on a vp44 going out ?
Old Feb 13, 2014 | 03:10 PM
mysterync's Avatar
There's not enough data to even guess. Your symptoms sound like a vp44 but that doesn't mean replace it. You really either need to do some diagnosis work or find a shop that can.
Old Feb 13, 2014 | 09:37 PM
i will do some more investigating i really just wanted another opinion to have all the possibilities that it could be thank you
Old Feb 21, 2014 | 05:16 PM
So i bought a edge evo ht and ecm is no issue but i got the p0216 The death code
jeremiah1
Jun 18, 2015 05:01 PM
Zachbishop
May 29, 2015 07:21 PM
flatbed_cowboy
9
Feb 26, 2015 04:30 AM
DSM1988
Jan 25, 2015 07:23 PM
PerformanceAuto
Jan 15, 2015 12:32 AM
