Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Injector / lift pump
Old Feb 7, 2014 | 09:50 AM
GTRW3T's Avatar
Default Injector / lift pump
Hey everyone
Been awhile since I've been on here but I need some help. I've been looking at installing a lift pump on truck along with some injector nozzles. I was wondering if yawl had any thoughts on what I should run. Truck currently has stock but new injectors that's y I was thinking about just doin nozzles I also have egr delete new head gaskets n been studded also running ppe standered Im looking to get some more power n wana make sure it's getting enough fuel that why I'm thinking lift pump any ideas?
Old Feb 15, 2014 | 12:54 AM
2004LB7's Avatar
i have a raptor 150. been working flawless for many years.
for nozzles, i would not go over 20% maybe 30% without some custom tuning. some get away with just upgrading the injectors and it runs fine. other end up with a lope in the idle and need tuning to fix it. the larger you go the worse it will be.
on the flip side, anything less then 20ish% is a waste of $$$ and not much gains. so i would say go for 30% overs and see if you need a tune after.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
