injectors and turbo time
Old Feb 6, 2014 | 10:11 PM
Mikey81's Avatar
Default injectors and turbo time
so im looking to upgrade my injectors and turbo. i tow minimally my hopes are to hit around 500rwhp. i have a 5spd gauges 4gsk, no fuel plate, blocked off wastegate, and hopefully soon 16.5 timing and 60lb valve springs.
i was leaning towards a set of dap 5x6 injectors and a super b or killer b. but i am unsure if im heading in the right direction
Old Feb 7, 2014 | 05:36 AM
turbo2332's Avatar
ive never heard of 5x6 injectors. those would be about twice as small as your stockers. ide recommend a set of 5x12's and a killer B. it will surge more than the super B but can make more power. the special will be noticeably more laggy over the other two chargers. and in the mean time dont be a tool, unplug your wastegate.
Old Feb 7, 2014 | 07:45 AM
Mikey81's Avatar
sorry i messed that up i meant 5x16
Old Feb 7, 2014 | 09:08 AM
turbo2332's Avatar
those would be MASSIVE for you truck, a 5x14 is roughly twice the size of a stock injector. you will melt the truck to the ground with that size of injector and such limited supporting mods.
Old Feb 7, 2014 | 07:29 PM
Mikey81's Avatar
limited supporting mods? DVs and a airdog would be the things to support the injectors right. Is there a better turbo and am i headed in the right direction
Old Feb 9, 2014 | 08:23 AM
turbo2332's Avatar
i mean like head porting and a camshaft. those are very large injectors for a truck that has mere bolt on performance mods. its still an engine, air in air out. not fuel dumped in and raw fuel belched out. you cant throw a 1050 demon on a stock small block chevy and expect it to run worth a CRAP can ya? same goes for a diesel you flood it out and it will run like hell. why attempt to run an injector that can support well over 700hp into a truck that you only want to get into the high 400 to low 500 hp range. it is a totally mis matched part for your application and you set-up will suffer.
Old Feb 9, 2014 | 09:58 AM
mysterync's Avatar
X2. Those would be great with head work, Twins or giant single, maybe some water or nitrous. But their not for a street truck daily driver.
Sent from my SCH-I605 using Tapatalk 2
Old Feb 9, 2014 | 04:50 PM
JasonQuartermile's Avatar
I run 5x18s on my 95 with no issues, but it's only a 160hp pump truck. They haze a little at idle in gear, but are otherwise fine to street drive. I'd do the 5x16s with the killer B and about 20 deg of timing if you can handle it starting a bit hard. I gained 50rwhp by going from 5x12s to 5x18s, but they do smoke more. I'd go with 024's on the DV's.
Old Feb 9, 2014 | 05:17 PM
mysterync's Avatar
I like the 7mm much more these days after trying them. I just feel for a towing or street injector a 5x14 or 5x12 has much better manners and egt control. We've got a customer with 215 pump that the 5x18s are just not streetable. How's life after diesel power?
Old Feb 9, 2014 | 06:57 PM
So far so good! I start at Brown's Diesel next month, so that should be fun. Also should still be doing some freelance writing, as the company just laid off a bunch of writers right after I left. I agree that 5x18s and a 215 pump is quite a bit of fuel, I think that the 160hp pump and towing twins (57/71) is what keeps my rig streetable. Towed 12,000lb up a 7% grade no issues with the 5x18s, you can cut out some of the low end fuel with AFC tuning and a fuel plate (or your right foot). Having the injectors set up higher at 300bar also seemed to make them run cleaner down low.
