1996 2500 12v help
Old Feb 2, 2014 | 03:11 PM
cummins Pride's Avatar
Default 1996 2500 12v help
ok guys a recent truck i got i was pumping up i took the intercooler line off from the intake horn and radiator and there is oil in the pipe is that ok
Old Feb 2, 2014 | 08:51 PM
six speed's Avatar
the bushings inside the turbo are probably letting oil by into the intake. i bet that there is oil in the exhaust also. sounds like it's about time for a rebuild or upgrade.
Old Feb 2, 2014 | 10:11 PM
what kind of upgrade just get another stock turbo
Old Feb 3, 2014 | 12:43 PM
cougar's Avatar
There will always be a small amount of oil leaked into the compressor and turbine sides as there is no positive seal. A small amount of oil can accumulate over 20 years of driving. If your oil consumption is normal, don't worry about it. Typically a quart of oil between oil changes is normal. The best deciding factor to overhaul or replace a turbo is shaft play.
Old Feb 3, 2014 | 02:42 PM
4x4manonbroke's Avatar
Agreed ..
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
cummins Pride
Dec 31, 2014 12:58 PM
Dec 29, 2014 10:20 AM
cummins Pride
Oct 28, 2014 07:49 PM
Lowcountry
Oct 19, 2014 11:00 AM
