01 24valve no fuel pressure, with a new fass lift pump
Old Jan 19, 2014 | 11:57 AM
customcummins's Avatar
Default 01 24valve no fuel pressure, with a new fass lift pump
Hello I have a 01 24 valve automatic with a factory replacement fass pump and mÿ lift pump stopped givin me pressure and I do believe I shut it down in time. I put another fass pump on and I am still not getting any pressure. I am getting power to my plug but my pump will not come on and register pressure. I ran 2 wires from the battery directly to the lift pump piggybacking through the factory harness and still get no pressure from the new LP. I did get a tps code and also replaced that and no luck. Any help would be greatly appreciated!! Thanks
Old Jan 19, 2014 | 11:42 PM
97cummins's Avatar
You could have a faulty new lift pump.
And have you checked to see If the gauge is still good?
Old Jan 20, 2014 | 06:10 AM
That I am going to check today. And for the gauge I'm not sure I just know that I cannot hear the pump kick on. So the gauge is next. The pump is a warranty one so if it is bad I will send it back again. Thanks any other ideas are greatly appreciated.
Old Jan 20, 2014 | 07:05 AM
mysterync's Avatar
Are you checking for voltage at the pump with it plugged up & attempting to run? Have you checked for voltage on the ground circuit (or you could do a voltage drop)
Sent from my SCH-I605 using Tapatalk 2
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
