Oil problem... Plz help
Old Jan 15, 2014 | 09:02 PM
Bigdonman1's Avatar
Default Oil problem... Plz help
I have a 96 dodge 3500 5.9l 12 valve. When I start it in the mornings it has perfect oil pressure but once the truck warms up my oil pressure drops to nothing but I can see the gauge move just a little when I idle it up to around 2000rpm but it's still at 0 pressure. I'm not getn any oil to my turbo or to the top of the engine after my pressure drops. I changed oil thinking that would help but still nothing. Does anyone knw what could be wrong?
Old Jan 15, 2014 | 09:17 PM
six speed's Avatar
i would say the oil pump is going out. how many miles are on the motor?
Old Jan 15, 2014 | 09:23 PM
Bigdonman1's Avatar
It has 218xxx miles on it. Do the oil pumps go out on them? There not much to the pump. I really dnt knw much bout diesels. That's y I'm askn questions
Old Jan 15, 2014 | 09:24 PM
mysterync's Avatar
How many miles?
Could be pump, the relief valve in the filter housing could be stuck open, excessive bearing clearance or possibly a leak in the pickup tube. Considering that it's low after warm up that may be an indicator of bearing clearance issues. Replacing the oil pump and checking the relief spring are fairly simple jobs so you could start with the relief and the the oil pump. It would be rare to experience a pickup issue.
Sent from my SCH-I605 using Tapatalk 2
Old Jan 15, 2014 | 09:29 PM
Bigdonman1's Avatar
I had the oil pump off today but put the old one back one. How can I tell if the old pump is bad?
Old Jan 15, 2014 | 09:52 PM
mysterync's Avatar
With a feeler gauge and the pump removed
Max Tip clearance of .0007" (tip of gerotor to planetary)
Max gerotor drive/planetary to port plate .0005" (back plate)
Max planetary to housing bore .015"
Gear backlash shouldn't exceed .015"
Backlash can be a pain to measure on these. What oil are you running?
Old Jan 15, 2014 | 09:55 PM
Bigdonman1's Avatar
I had rotella 15 45 in it when it started messn up then I put delo400 in it when I changed it but I'm gona change back to rotella when before I change the pump
burndiesel
10
Feb 7, 2023 01:15 AM
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
Gomerpile79
Apr 9, 2015 03:45 PM
