98 6.5 no start
Old Jan 6, 2014 | 03:16 PM
Bellamy4's Avatar
Default 98 6.5 no start
Can't get my my 98 6.5 started It has the block heater and a magnetic oil pan heater on it and two brand new batteries! It barely wants to crank! I ordered new glow plugs but am not at home today so any help in the right direction would be nice for when I get home!
I should also post its -30 degrees Celsius up here in canada
Old Jan 7, 2014 | 11:22 AM
racer55's Avatar
Corroded battery cables and maybe bad starter?
Old Jan 7, 2014 | 11:32 AM
Bellamy4's Avatar
I'm thinking its the new batteries actually cause I put them in my 05 Cummins and it barely turned over too gunna take them back and try the new ones
Old Jan 11, 2014 | 01:11 PM
jrsavoie's Avatar
Always have batteries load tested when you pick them up. I've had way to many new, bad batteries in the last several years.
Testing for voltage doesn't do any good. I've had batteries that tested good for voltage before and after a non-start
A load tester is a cheap diagnostic tool to have around. It can pay for itself in reduced trips to the parts store.
I bought a couple of good quality load testers on Ebay for in the $30 range
I've heard that Harbor Freight also has a decent Load tester - cheap
Old Jan 11, 2014 | 03:48 PM
Mayhem's Avatar
I have a HF digital load tester less than $30 works great And if you have 1 bad battery replace them in sets
Old Jan 11, 2014 | 05:01 PM
jrsavoie's Avatar
You want to disconnect the battery cables and load test them separately about 20 minutes after charging. Sometimes they test good immediately after charging and test bad after about 20 - 30 minutes
Old Jan 14, 2014 | 02:06 PM
Jake Stewart's Avatar
Cheap diognosis to see if theyre bad, pop caps off and put an alka-seltzer in each one and see if it cranks after that. Causes a chemical reaction with the permeable layers and keeps battery strong for a while if starting to go bad.
Old Jan 14, 2014 | 05:12 PM
jrsavoie's Avatar
PRODUCTS
has a battery cable set for the 6.5's. I'm sure there are others as well
penley`
Jun 7, 2015 04:38 PM
petew
Jun 2, 2015 07:33 AM
flyer
Dec 9, 2014 07:53 AM
bdemutis
Dec 7, 2014 01:36 AM
Daniel Leipart
Oct 6, 2014 08:17 PM
