Fuel Filter
Old Dec 29, 2013 | 02:53 PM
Highlander's Avatar
Default Fuel Filter
How often do you guys change your fuel filter, I put about 12.000 on in a year. I got a problem with high idle at around 1000rpm and my check Engine light came on..I put on a new pmd still the same thing, would the fuel filter cause this.. once the truck is fired up you turn it off and start it back up it's fine..idles around 7000, but once you step on the peddle it revs high again.
Old Dec 29, 2013 | 04:07 PM
dallonj's Avatar
I change mine every second oil change sounds like. bad sensor
Old Dec 30, 2013 | 07:28 AM
Highlander's Avatar
I just changed the pmd yesterday, so I disconnected the Battery Cables over night.. hoping the check engine light is out when I hook them back up.. gonna have too wait a while for that, big snow storm on here now..
Old Dec 30, 2013 | 08:30 AM
racer55's Avatar
Go to your local parts supply and get them to do a free code check,write don the code #'s and post them here so we can help figure out what the problem might be?
On anything newer than 95 taking the battery cables off does nothing to clear codes,a code checker or scan tool is needed.
Old Dec 30, 2013 | 07:07 PM
Highlander's Avatar
Put cables back on..check engine light is out, but still revs high. the problem here is I'm about 2 hours drive from a parts place.
Dbleo351
Nov 20, 2016 09:34 AM
jeffersonl
Nov 15, 2015 07:35 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
james2562
Oct 8, 2014 06:14 PM
