Antifreeze Low
Old Dec 22, 2013 | 09:25 PM
skirk55's Avatar
Default Antifreeze Low
I checked my antifreeze and it was low! The bottel was empty. Is the the head gasket leaking?
Old Dec 23, 2013 | 02:16 AM
97cummins's Avatar
That's possible
Have you pressurized the system to check for leaks?
Old Dec 23, 2013 | 02:17 PM
skirk55's Avatar
No it is snowing or raining! I hate winter! At work I looked for leaks and found thr hose clamp is wet. Nothing around the motor. Oil is ok. Stinks.
Old Dec 23, 2013 | 07:06 PM
Billy D's Avatar
Is it wet inside the cab? Heater core maybe?
Old Dec 25, 2013 | 08:30 AM
skirk55's Avatar
No nothing. I filled it to the cold level. It took about one quart. It was just below the add level.
My 2005 F350 6.0 diesel pushed the antifreeze out of the bottle and it was all over plus the smell.
Next week I will do a pressure test at work.
Old Jan 8, 2014 | 07:17 PM
AFRenoughsaid's Avatar
Check for line leaks
Old Jan 8, 2014 | 08:39 PM
H.R.D's Avatar
If the above posts don't help you find the issue it could be a possible water pump failure. Remove the serpentine belt and turn the water pump my hand, if leaking you will see it come from the weep hole on bottom.
corksil
Aug 2, 2015 10:19 PM
soco
Jul 27, 2015 06:06 PM
robbyS
Apr 16, 2015 02:22 PM
jorttel
Feb 22, 2015 09:50 PM
tumble72
Nov 20, 2014 12:31 AM
