Lost Reverse?? Any ideas?
Old Dec 18, 2013 | 11:50 PM
1996Cummins's Avatar
Default Lost Reverse?? Any ideas?
I have a 96 2500 Single cab, automatic transmission. A few weeks ago I went to put it in reverse and it wouldn't go into gear at all. All forwards gears worked just fine, but reverse is nowhere to be found. It happened after hitting a few large potholes down a bumpy road, but I'm not sure if they're connected. I dropped the tranny and am getting ready to open it up and take a look to see if I can find the problem before I take it to a shop. Any ideas on what it could be, or what to look for?? Any help is appreciated, thanks.
Old Dec 19, 2013 | 01:13 AM
Dynamic's Avatar
If all your forward gears are working, you probably have a rear band issue. It's also possible that you have lost your OD direct clutch in the overdrive.
You'll have to tear it down and find out...
Old Dec 19, 2013 | 04:34 AM
I'll take a look at that when I get it open. Thank you for the suggestion
Old Dec 22, 2013 | 02:26 AM
Slim Whitey's Avatar
was it banging into reverse before it finally quit?
Old Dec 23, 2013 | 03:41 PM
Sometimes and sometimes it would only go in if I flipped OD off
99&91cummins
Feb 28, 2015 09:28 AM
97PS
14
Feb 19, 2015 11:21 AM
alex74708
Dec 18, 2014 07:54 PM
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
Nov 29, 2014 12:40 AM
4estlee
Oct 7, 2014 07:47 PM
