Help 4x4 issues, maybe related to ABS
Old Dec 8, 2013 | 10:50 AM
pacarriere's Avatar
Default Help 4x4 issues, maybe related to ABS
Hi Guys, im pretty new to the ford diesel world and need some advice and any help that can be given.
I just replaced the front right wheel bearing. Everything was easy to do, i re-connected the abs sensor and was done.
Now when i drove the truck after, i get a buzzing sound from when i apply the brakes and i believe my 4x4 is not engaging anymore.
I searched the forum for 4x4 issues but have not found anything.
1- Does the ABS system have any say on the 4x4
2- Anybody ever experience the same thing with their brakes.
Im thinking of removing the ABS fuse, but right now i got a leg in a cast and cas move around. AT least im trying to get some info for when i can work on the truck again.
Thanks for any help you can provide
P-A
Old Jan 5, 2014 | 12:39 PM
Kevinmccormick's Avatar
I have the same issue. I had to replace the front left hub, after I got the truck back the steering and brake peddle have a wining noise and a lot of vibration. I have already replaced the speed control sensor on rear axle, abs light went away, but no change in the cab. I am going to check the steering pump next.
Old Jan 17, 2014 | 07:05 PM
2001psd's Avatar
Default Lines
Maybe the vacume lines that enguage the otf hubs got pulled off.
dwmeehan
Jan 29, 2025 12:13 PM
cjt8569
Sep 29, 2015 06:39 PM
Dec 7, 2014 11:20 AM
Polaris04
Dec 1, 2014 08:27 AM
Sculpturesylvan
Oct 18, 2014 10:19 PM
