hot tranny need help
Old Dec 4, 2013 | 06:31 PM
brodys73's Avatar
Default hot tranny need help
Hey guys i was driving my 02 around today and didnt go very far and noticed the transmition gauge was running way higher then normal. what could this mean and what should i do?
Old Dec 4, 2013 | 08:55 PM
gunman41mag's Avatar
Moderator
Check your transmission Fluid
Old Dec 5, 2013 | 04:22 PM
brodys73's Avatar
fluid levels are good smells a little burt thu
Old Dec 6, 2013 | 02:28 PM
markanthonyhudson's Avatar
Change fluids and maybe install a new filter in the pan
Old Dec 7, 2013 | 10:49 AM
Kelvin Porter's Avatar
Check your transmission cooler lines to make sure they are not pinched going to and coming from the transmission cooler
Old Dec 11, 2013 | 02:35 PM
Dynamic's Avatar
As mentioned, check your fluid level and the cooler lines. Also, check to make sure your converter is locking up like it's supposed to.
Digging deeper, I'd pull the cooler lines and check for restricted flow. The converter clutches like to come apart in those and send debris out into the cooler. Much restriction and the bypass tube will open, allowing the fluid to bypass the cooler system completely.
How high is "higher than normal"?
camp9
Mar 25, 2017 07:40 AM
drsparkman
Nov 4, 2015 10:32 AM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
