7.3L problems
Old Dec 3, 2013 | 08:01 PM
tstacoma's Avatar
Default 7.3L problems
I got a 1995 f250 four wheel drive got it for cheap ($3,000) Arkansas truck no rust, my buddy got it when it had no motor so he had to put a motor in the truck, he got a 1996 7.3L he sold it to me without it running so I finished up the motor job got it done and got it started well it smoked so much white it burned your eyes so we drove it out side (at 20 degs) it wouldn't idle we held down the throttle at 1,000 rpm until it was warmed up then it idled took it down the road it had no power and smoked so bad you couldn't see the road, well going up and over a hill it shut off and won't start got her towed home and found starter was stuck to the flywheel replaced starter and still did nothing found out the power cable starter to battery was rubbed threw and shorted out well my question is why did it shut off I was thinking IPR?? Haven't had time to get it started again but I need help what could white smoke be bad injector o rings? From the motor sitting?
Old Dec 3, 2013 | 08:08 PM
autostroker's Avatar
Bad injector orings could cause the smoke, lack of power and shut down. If its loosing enough high pressure oil it eont fire the injectors
Sent from my SCH-R970 using Tapatalk
Old Dec 3, 2013 | 08:11 PM
tstacoma's Avatar
Is there a good way to test for injector o rings
Old Dec 3, 2013 | 08:23 PM
Not sure if buzz test would work or not... only other way i know is to have it running and see if oil dril spouts are pouring oil out like they should.
Old Dec 3, 2013 | 08:24 PM
joebob3093's Avatar
Moderator
not really, you have to pull them. but once you pull them you have to replace them. its not wise to reuse them
Old Dec 3, 2013 | 08:29 PM
Not too bad of a job anyway.
Old Dec 3, 2013 | 10:11 PM
joebob3093's Avatar
Moderator
Takes me 4-6 hours depending on how everything is cooperating
Old Dec 5, 2013 | 02:41 PM
7.3OilPanRepair's Avatar
FormerVendor
Inexpensive and fairly easy repair. Do the glow plugs too while your under the valve cover. Replacing the orings on mine didnt stop it from smoking, but I did find a few that were brittle and cracked. You can get the orings for like 7bucks per injector. I think mine is still smoking because the injectors are worn and 15w oil is so thick when cold.
Everything is normal if the block heater has been plugged up for a few hours
Bloom12valve
Oct 9, 2015 03:40 PM
Brody Olson
Chevy/GMC Duramax 06-07 LBZ
Sep 12, 2015 11:01 PM
Dye Guardian
Aug 1, 2015 01:28 PM
Bstehle
Feb 3, 2015 07:24 PM
Blue Briar
Oct 5, 2014 08:23 AM
