Leaking IP question
Old Dec 1, 2013 | 02:47 PM
crew-it's Avatar
Default Leaking IP question
Hi all. My IP is leaking from just below the torque screw. It's coming from the fitting under the red plastic cover shown in the pics. From what I have researched, it's the guide stud which holds down the metering valve assembly?? I'm sure there's a seal on the guide shaft but from what I can see in the stanadyne drawing, you can't pull the guide stud without things coming apart on the inside? Is that right? I guess my question is, can I pull the guide stud and try to re-seal or is it holding a bunch of other parts in place, that will come apart if I take the guide stud out? I'm hesitant to pull of the red plastic cap as it's pretty brittle and I know it will break if I do that and don't want to screw anything up. Thanks in advance.
Old Dec 1, 2013 | 10:53 PM
4x4manonbroke's Avatar
never seen that before ... .. gonna go look at mine now .... gots me curious .
Joracing3
Sep 10, 2016 05:28 PM
Josh_L
Apr 12, 2015 12:12 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Stox5225
Nov 18, 2014 01:04 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
