GPR voltage
so my truck hates starting in the cold, any where near freezing or below, so starting simple i checked the GPR. as typical i have 12 volts to the side that has constant power, but only 9 to the side that gets power once your ignition is turned onto the on position... could that be my problem, or at least part of it ?
OK, so i was outside and measured the ohms on each of the pins going to the glow plugs, they all measured between .2 and 2.0 ohms, BUT the plug on the passenger side rear is a little melted and smells burnt.... so i am assuming its bad?
if so where can i order one, and any info on changing it would be greatly appreciated.
Last edited by 97dieselnewb; Nov 26, 2013 at 04:49 PM. Reason: Automerged Doublepost
You can order the dorman kit online and it should come with new pigtails... I would recommend doing both sides and new glow plugs and a relay. That will cover everything that aids in cold startup. Only other thing is oil quality and injectors. If it gets really cold changing to a synthetic 5-40 will help a ton...
Sent from my iPhone using Tapatalk 2
it never gets super cold here... maybe around 0 degrees a couple times a year, but I plan on doing the wires and stuff asap, and i want to get injectors from swamp with my tax return, so since the glow plugs test good ill wait to do them until then.... unless i change the wires and pig tails and im still having issues... but since the test within spec I am thinking i wont, hoping i wont
john grossman
10
Jan 12, 2019 08:58 PM
Saams69
Jul 20, 2015 11:21 PM
91firstgen
May 2, 2015 01:07 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
