4X4 Problems HELP!!!!!
Old Nov 25, 2013 | 02:49 PM
easye1's Avatar
Default 4X4 Problems HELP!!!!!
I have a 2003 F250 and the 4x4 will not work. I have replaced the turn *** switch and the relays under the hood I believe there are two. It will not even light up on the dash. I do not know what it could be
Old Nov 25, 2013 | 04:33 PM
bigbull7.3's Avatar
Its probly the shift motor on the transfer case
Your shift motor on the transfer case is most likely out.
Last edited by bigbull7.3; Nov 25, 2013 at 04:33 PM. Reason: Automerged Doublepost
Old Nov 27, 2013 | 07:18 AM
O_Boy's Avatar
that happened to mine right after i bought it it ended up being the plug on the transfer case motor wasn't latched all the way in.
something easy to check if you haven't..
jimmer4dat
Sep 10, 2015 01:07 AM
Wyattbyrd
5.9L CR Performance
May 28, 2015 10:32 AM
cummins1998.5
Jan 24, 2015 03:06 PM
mabr0503
Nov 27, 2014 01:36 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
