smoke switch
Old Nov 24, 2013 | 12:37 PM
better_off_witha_diesel12's Avatar
Default smoke switch
Is there anyway to put a smoke switch on one of these trucks without.a tuner or anything?
Old Nov 24, 2013 | 12:38 PM
autostroker's Avatar
Good god why........ just put a smoke bomb in the tailpipe.
Sent from my SCH-R970 using Tapatalk
Old Nov 24, 2013 | 02:00 PM
joebob3093's Avatar
Moderator
Its called a rag in the fuel tank then Light it on fire
Old Nov 25, 2013 | 08:20 PM
Man!!!, Theirs no need to be a smart ***! Just answer my question!! People like you make this website suck!
Old Nov 25, 2013 | 08:30 PM
Guess ive never heard pf a smoke switch for a powerstroke......smoke is just unburnt fuel. Programmer or onjectors would probably be the easist way
Old Nov 25, 2013 | 10:44 PM
joebob3093's Avatar
Moderator
only idiots want a smoke switch, dont be a douche
Old Nov 26, 2013 | 03:39 PM
Buckage1234's Avatar
Mindblower has some inexpensive chips you can add on you IAT that will blow a little smoke...around $30 bucks on EBAY..add about 50HP...other than that, I got a bad IDM and it will smoke up the whole neighborhood in about 5 minutes but that is the bad white smoke....tons of unburnt fuel. A decent programmer with a cold air intake kit should do the trick at the 140 switch setting. Dumping in more fuel, either burnt (black) or unburnt (white) is the only way I know to get more smoke.
Old Nov 30, 2013 | 09:58 PM
That1Guy's Avatar
Smoking is pointless unless your making huge power and its just gonna happen smoking like what you want just gives us diesel guys bad names .. but if you insist on it you can wire a switch into the map sensor wire turn off map voltage = more smoke just google it
mattshow123
14
Mar 12, 2018 01:41 PM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
IslanderXJ
Dec 17, 2014 04:14 PM
7.3lfordguy
8
Oct 17, 2014 11:45 PM
perk7089
Sep 30, 2014 07:33 PM
