05 6.0 psd bubble tester question
Old Nov 18, 2013 | 05:27 PM
jlpoperator's Avatar
Default 05 6.0 psd bubble tester question
I just got my bulletproof diesel bubble tester in the mail and went out and hooked it up... no bubbles.. at all. Unplugged the turbo harness.. no bubbles still. What gives?! Any help is much appreciated as I was told by a mechanic I need head gaskets. Thanks in advance guys.
Jeff
Old Nov 25, 2013 | 06:39 AM
Adrenaline junkie's Avatar
What is wrong with your truck? Why u think head gaskets?
Old Nov 25, 2013 | 03:14 PM
Losing 1/2" of coolant out of degas bottle a month. N I have brown gunk in degas bottle also
Old Nov 25, 2013 | 07:17 PM
I would check compression thru glow plugs. Usually the oil cooler is a bigger issue than head gaskets when there is oil in degas bottle. If compression good I would suspect oil cooler as source of problem.
twilks445
Mar 4, 2015 04:26 AM
Bigredpowerstroke
Nov 25, 2014 03:21 PM
