6.9 glow plugs
Old Nov 15, 2013 | 10:59 AM
jerry g's Avatar
Default 6.9 glow plugs
have a 6.9 1986 ford 250 that keeps burning out the glow plugs, bypassed the controller and now is push button. any ideas as to what glow plugs to use. not autolites!
Old Nov 15, 2013 | 10:12 PM
RedChevy44's Avatar
Welcome!
Old Nov 18, 2013 | 12:10 PM
powerstrokin350's Avatar
I was curious about what glow plug would be recommended for my 1993, I was looking at some Diesel Rx. Are these good, says for 6.9/7.3L
Old Nov 18, 2013 | 05:52 PM
Dortiz's Avatar
Motorcraft ZD9's, But I run autolites in my truck with no problems what-so-ever
Old Nov 19, 2013 | 09:38 PM
Sycostang67's Avatar
Use the motorcraft plugs, I had to pull swollen autolites out of both of my IDI's. You actually need the ZD1A plugs for the 6.9, the ZD9 plugs are for the 7.3. When using a push button on the 6.9 with the ZD1A's, only run them for 10 seconds.
Old Nov 19, 2013 | 10:02 PM
Dortiz's Avatar
You're right on the brand, my bad was thinking he had a 7.3 for some reason
Old Nov 20, 2013 | 03:21 PM
4x4manonbroke's Avatar
ive had the autolights in for more than 5 years and haven't had a single issue with them ..... not sure why everyone says there not good .... mine looked great when I pulled the heads off ... wire wheeled them and re-installed with some anti-seize ....
Old Nov 21, 2013 | 10:31 PM
Some people believe the swelling could be due to people running a push button setup and running the plugs for too long. On my 86 that could have easily been the case as it had a push button on it and 5 swollen autolite plugs. My 93 however had and still has a factory controller and I removed 3 swollen autolite plugs from it when I got it. I took the few good autolites from the 86 and hooked them up to a battery charger. One of them glowed for about 15 seconds then burnt out, the other two swelled up right before my eyes. The quality control may have gotten better since then, as the plugs I pulled from the 86 were likely installed in the mid 90's and you don't hear many swollen plug stories from ones that were recently installed these days.
Metz1234
Mar 3, 2016 10:20 PM
rkp209
Chevy/GMC Duramax 2011 LML
Jan 10, 2016 10:32 AM
GT_Eleanor
Sep 14, 2015 10:52 AM
1997silverado
Mar 12, 2015 07:40 PM
hardwired
8
Jan 23, 2015 04:30 PM
