97 powerstroke rpm hang
Old Nov 4, 2013 | 10:15 PM
dieselkidd01's Avatar
Default 97 powerstroke rpm hang
just changed my injectors when i rev the engine the rpms dont just drop they hang and slowly drop its also low on power hot or cold it takes the same amount of cranking to start like its losing its prime? and no excessive blowby ideas?
Old Nov 4, 2013 | 11:45 PM
joebob3093's Avatar
Moderator
How many miles on it since you swapped them?
Old Nov 5, 2013 | 05:55 AM
autostroker's Avatar
Run the **** out of it ti get the high pressure oil primed. Drive it like you stole it for a week.
Sent from my SCH-R970 using Tapatalk
Old Nov 6, 2013 | 12:08 AM
found it maniflod pressure was disconnected from taking the valvecover off haha but im pretty sure my dualmass flywheel is toast constant noise from the clutch area and vibration and only like 20 miles since i swapped them
Old Nov 6, 2013 | 12:12 AM
joebob3093's Avatar
Moderator
You still have air in it. Can take 50+ miles to get the air out.
Old Nov 6, 2013 | 12:17 AM
thanks for the info never swapped a set before since my truck is cali what should my fuel pressure be? an does the flywheel make noise when it goes out because the engine sounds smooth but it slightly shakes and there is constant clunk coming from the inspection plate
Old Nov 6, 2013 | 12:34 AM
joebob3093's Avatar
Moderator
The dual mass ones make some noise, been a while since I have been around one so I can't remember. I have my fuel pressure set at 68psi
Old Nov 6, 2013 | 12:38 AM
i wanna get rid of the dual mass regardless but damn its expensive and i appreciate the help
Old Nov 6, 2013 | 01:08 AM
joebob3093's Avatar
Moderator
They are a lot cheaper then an auto Lol. My clutch was 1700
Old Nov 6, 2013 | 01:15 AM
true haha only reason i have my powerstroke is because i hate autos with a passion and my idi was an auto i paid 500 bucks for my powerstroke as parts for the 5sp conversion turns out the powerstroke was savable
BlueBell2000
Sep 10, 2015 05:33 PM
Lsugod85
Jun 20, 2015 05:14 PM
stump
5.9L CR Performance
Jun 11, 2015 09:52 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
