KOKO
Old Oct 26, 2013 | 07:32 PM
blacksally's Avatar
Default KOKO
I did a key on key off relearn and the truck would idle at about 1200 and real lopey ??? then I shut it off restarted did the same till I unplugged pmd and hooked up other one then changed it back andf it was good?
Old Oct 28, 2013 | 08:25 AM
racer55's Avatar
What was the new TDCO value?
Did PMD have a resistor in it?
Clear codes before KOKO?
Temp 170 f+ before KOKO?
Any codes now?
Old Oct 28, 2013 | 09:31 PM
blacksally's Avatar
im thinking it was only about 160 f idk what the tdco was I had no codes before or after and there is a resistor in the pmd I see
Old Oct 28, 2013 | 11:16 PM
racer55's Avatar
The temp must be 170F+ to do the relearn and when you do a KOKO you must have a scan tool that will display the TDCO value so you know if more adjustment is required to get in rang.
stock TDCO values are -0.25 to -0.75
performance values are -1.50 to -1.94
In both cases the negative value is important,it denotes advanced timing while a value that appears posative denotes retarded timing.
Old Nov 2, 2013 | 05:47 PM
racer55's Avatar
Did you get anywhere with the problem?
Old Nov 3, 2013 | 09:20 PM
blacksally's Avatar
I never did it again I left it alone I havnt messed with timing it seems to run good idles at about 600-590 the timing is at 2.9 the diesel guy I talked to said leave it? could I move it towards driver side just a tis and koko?
Old Nov 3, 2013 | 11:27 PM
racer55's Avatar
2.9 means absoloutly nothing unless he did timeset instead of TDCO?
Even then I would say it's retarded.
