1997 6.5 Differences from 1995?
Old Oct 23, 2013 | 11:43 PM
Levis95's Avatar
Default 1997 6.5 Differences from 1995?
Ok so heres the deal I was originally going to swap in a 1993 6.5 into my 1995 but I have been delayed and delayed. Then my buddy decided to sell his 97 6.5 with 188 000 kms on it for 700 bucks running and driving just body was **** so I snatched that up and now I plan on swapping it into my 95 because I believe it would be an easier more straight forward swap. So what are the differences between the 95 and 97 because I noticed the alternator is on the other side and it has a MAF. Havent looked too far into it but my question is when I swap it what do I need to change over? My buddy thinks i should switch ECUs wiring harnesses and gauge clusters what are your thoughts on that? Thanks guys
Old Oct 23, 2013 | 11:53 PM
racer55's Avatar
Make the 97 long block look just like the 95 everything will work together just fine-Ignore the maf since your 95 ECM can't connect to it or control it otherwise it is the same.
Old Oct 23, 2013 | 11:55 PM
Levis95's Avatar
so just move the alternator over and a few other things and then plug it all in? Im hoping to do this all in a weekend so my truck wont be down for too long
Old Oct 24, 2013 | 12:29 AM
racer55's Avatar
Most likely you will have to swap the entire frt bracket assembly from one engine to the other-they are completely different-it's not just move the alternator.
6.5jones
6.2L & 6.5L Performance
11
Apr 3, 2017 01:38 PM
krg3590
Mar 15, 2015 08:57 AM
airspeed181
Jan 19, 2015 09:00 PM
Blake35
Dec 8, 2014 11:15 AM
gremlin75
Oct 6, 2014 06:10 AM
