oil in gas
Old Oct 19, 2013 | 03:37 AM
bangonit's Avatar
Question oil in gas
friend of mine had a bad injector he replaced it but it didn't seal all the way in he eventually started losing oil pressure he checked the oil and it had diesel fuel in it so he changed his oil in a parking lot when he was done he didn't no what to do with the oil he figured it was mostly gas so he dumped it in his tank then he drove it home I helped him put the injector back in but now it wont start he has an air dog on it I was wondering what any one thinks I took the stock oil filter off cause I thought it wasn't priming and it had blackish gas in it any one have any suggestions on what to do next gonna go help him today I just changed all my injectors about 2 months ago only problem I had was sleeve came out. he has a 03 duramax with air dog cold air intake and edge programmer
Last edited by bangonit; Oct 19, 2013 at 03:41 AM. Reason: let everyone now model and mods
Old Oct 19, 2013 | 02:26 PM
2004LB7's Avatar
I have run a lot of used motor oil (UMO) in my LB7 but I filter it really good first. The only times I ran into trouble was when I didnt
The umo will clog up fuel filters real fast if not filtered first before putting it in your tank. I would drain the tank and replace the fuel filter and see how that goes.
The older mechanical injectors where more tolerant of umo but not these high pressure common rail engines
Old Oct 19, 2013 | 09:58 PM
bangonit's Avatar
found the problem was bad injector wire harness
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
