Front and Rear Main Seals
Old Oct 10, 2013 | 01:58 PM
slipagnt's Avatar
Default Front and Rear Main Seals
Anybody out there renting or loaning out their front and rear main seal install tools for a Lb7? I don't wan't to buy them if I don't have to.
Old Apr 26, 2014 | 08:22 PM
4x4manonbroke's Avatar
In some cases when ther both leaking like that ... We ... in the heavy diesel industry tend to start looking at the lower end and inspect the bearings to ensure that the crank isnt sagging due to bearing wear or failure begingin .....just food for thought .... might wanna check that out.
also turbo seals blowing boost into crank case through the oil return line(s) ...
Old Apr 27, 2014 | 10:13 PM
slipagnt's Avatar
I had the motor out for a rebuild.
Old Apr 28, 2014 | 08:55 PM
ahh ... how didi you pull and install them before ?
Old Apr 29, 2014 | 06:13 AM
slipagnt's Avatar
The motor had 300,000 on it so the seals were original. It was a complete tear down so I just knocked them out when the front and rear covers were off.
Old Apr 29, 2014 | 05:28 PM
The crummy part is ur gonna have to pull trans. ... Again ...
the front I would just pull cover and redo ... Save some hassel there ... The rear ... Is it a bolt in one piece ??
shingi
Off Roading
Sep 30, 2015 11:17 AM
2FordStrokers
Jan 11, 2015 09:40 PM
dougcarlo
Oct 18, 2014 03:15 AM
