Turbo problem
Old Sep 27, 2013 | 02:53 PM
Diggy6.5L's Avatar
Default Turbo problem
So my turbo has started leaking a lot of oil and ive had numerous people tell to rebuild it and others told me to replace it . what is the best option and what do you guys think the exact problem is? help please
Old Oct 2, 2013 | 02:14 AM
bigdaddyinacaddy's Avatar
Where is it leaking oil from, around the blades on the intake side or out of the oil feed or return? If it is leaking from around the blades, it should be replaced immediately. That means the bearings are failing. You don't want that thing grenading and sending bits and pieces into the engine, that would be the end. I would just throw the stock turbo away and replace it with a holset hx40w or similar. You will be amazed at the difference.
Old Oct 15, 2013 | 05:43 PM
Bomber4life's Avatar
Is there not going to be a bit of oil on the intake side ?
Old Oct 15, 2013 | 09:23 PM
Yes a little is fine I'm talkin about a lot. The residue on the air filter side is from the cdr valve, the hose ran from intake tube to passenger side valve cover.
Old Oct 15, 2013 | 10:59 PM
Ok yah I thought so thanks bud
Old Oct 15, 2013 | 11:21 PM
racer55's Avatar
There are no bearings in a stock 6.5 turbo-the impellers are suspended by bushings.
As long as there is little to no side play in the impellers the turbo is likely alright.
You need to identify where the leak comes from if it even is a leak-a bad CDR can make enough oil appear near the turbo to make it seem like a leak.
As far as replacement goes the ATT turbo is the only aftermarket direct bolt on available that doesn't even need the vac system since it is non wastegated.
It's more efficient than any of the GM turbo options also
Old Oct 17, 2013 | 10:12 AM
ENG62INE's Avatar
Replace it man, mine was leaking on the intake side and i ignored it. Came back from a road trip and it started screaming. Pulled the filter off and it shredded the compressor wheel. Could have saved myself a huge headache if i replaced it right away.
Old Oct 18, 2013 | 09:41 PM
Diggy6.5L's Avatar
I rebuilt it and the leak stopped there still little spots on the intake side but my boost is 10 times better and it's not leaking down to my frame anymore I'm probably replacing it soon anyway
Old Oct 18, 2013 | 09:53 PM
ENG62INE's Avatar
The rest of the oil may be your CDR valve, AKA the tuna can, they're around $50-60 to replace
Old Oct 20, 2013 | 10:07 AM
Mayhem's Avatar
Cheaper alternative soak CDR in some Diesel fuel blow it out with compressed air it will be as good as new
burndiesel
10
Feb 7, 2023 01:15 AM
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
