where to set injection timing at? mod list inside
Old Sep 11, 2013 | 10:11 AM
dixierebel0213's Avatar
Default where to set injection timing at? mod list inside
I just purchased a 188/220 Hamilton cam, arp studs, and a 24 valve oil pump to help repair my recently deceased 12 valve. I was wondering if you had a suggestion on where I should time my injection pump at. I have looked around and talked to several people and im trying to pinpoint where I would be best. I have a 1997 dodge 2500 4wd on 35" tires, it is a manual with the 215hp pump. I have a bd 63/65/14 turbo, 5x.013 injectors, no fuel plate ( which may change according to towing egts and smoke), 60lb valve springs and a 4gsk, and a valair 400/1000 clutch. the truck is a daily driver but does see an occasional car and trailer, or a load of fourwheelers up through the mountains. thank you for you input
Old Sep 11, 2013 | 05:16 PM
turbo2332's Avatar
16-20 your preference or the power curve
Old Sep 12, 2013 | 02:21 PM
I have heard that 17* or better will spray outside of the factory bowls, which in turn creates excessive egt and smoke is there any truth to this? where would the power curve shift to from 16* to 20*
Old Sep 12, 2013 | 05:34 PM
turbo2332's Avatar
the higher the timing the higher up in the rpms the curve will go.
moneypitk5
Feb 12, 2015 11:01 AM
jkidd
For Sale
Dec 9, 2014 12:33 PM
jkidd
Diesel Auto Power
Dec 9, 2014 12:16 PM
SMatyac
Nov 15, 2014 07:35 PM
