Comand start not working?
Old Aug 5, 2013 | 01:17 PM
petew's Avatar
Default Comand start not working?
Recently I had to replace the Vac pump, and when doing this I disconnected the battery to get the wires out of the way. Now I do not have a command start. This happened as soon as I hooked the battery back up, and I can not find any wires that are not hooked back up. When I push the start button nothing at all happens, no pump, no dash , nothing at all. Everything is fine with the key. I tried the other start fob and same thing. The door lock function works fine with both fobs.
I am at a total loss on where to look for the problem . This is the factory command start on a 97 GM 6.5 K1500.
Old Aug 5, 2013 | 04:19 PM
Mase's Avatar
Make sure your starter wires are still tight.
Old Aug 9, 2013 | 09:21 PM
petew's Avatar
good old UTube came thru for me. The problem came from disconnecting the battery, and the command start lost it's memory for the start mode. Easy fix, is turn key on and off 5 times, then press the lock button, wait 5 sec, and you hear a couple clicks as the command start shuts down.
That's it, press start wait a couple seconds, dash lights come on and when the glo plug is hot it cranks and runs.
Old Aug 10, 2013 | 12:31 PM
Mase's Avatar
Glad you figured it out.
JPT18
Mar 6, 2016 11:20 AM
Aug 10, 2015 06:40 PM
Mar 25, 2015 01:50 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
hemiheath
Oct 15, 2014 11:49 AM
