Little Boost then no Boost
Old Jul 22, 2013 | 11:53 PM
Gacinaz's Avatar
Default Little Boost then no Boost
2000 F350 Superduty 7.3L 2wd manual trans
The truck runs fine on flat ground. When I walk on it I am only getting 5 - 6 pounds boost which it holds for a few seconds then drops off to zero and run very rough until I pull over, shut it off for a few seconds and then it will smooth out. Down shifting and easing off the gas does not make it run smoother. It will also start to run if I crest the hill and start down. Same thing when climbing long hills, even without a load. No codes and no fault lights. I tried disconnecting the map and I get service engine light but no change in performance. Does not blow any smoke. I did change out the HPOP O rings a few weeks ago but ran fine after that. I did not remove the HPOP fitting springs or wafers. Oil pressure, temperature are normal. Also replaced the fuel filter and filter O rings after I started having the loss of power.
Old Jul 23, 2013 | 01:41 AM
MossBack's Avatar
Sounds like you need to check for any exhaust leaks. Manifolds to block up pipes and doughnuts are famous for leaking.
Sent from my iPhone using Tapatalk 2
Old Jul 31, 2013 | 07:31 PM
Gacinaz's Avatar
I checked exhaust for leaks, I checked intake for boost, I checked static fuel pressure, I replaced the fuel and air filters. Nothing helped. Then I checked dynamic fuel pressure and found that under load the primer pump was not supplying enough fuel. Replaced pump and everything is back to normal.
Thanks for the help.
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
