Four Wheel Drive actuator Snapped off, but still threaded inside.
Old Jun 30, 2013 | 04:12 PM
DuramaxDiesel02's Avatar
Default Four Wheel Drive actuator Snapped off, but still threaded inside.
Went to go replace my 4WD actuator but it would not unscrew, and after some really hard twisting with a pipe wrench the plastic actuator snapped off at the threads, leaving it threaded inside the transfer case still but now there is nothing to grip to get it out!
Fluid also leaks a little bit and it doesnt look like their is anyway to get out un threaded especially since it was threaded in real tight.
SO do I need to remove my transfer case to get it out? I cant see any other way I could.
Thanks guys
6.5dieselman
Feb 26, 2015 04:45 PM
MAC4232
Jan 28, 2015 01:46 PM
2002cabandchassis
Oct 29, 2014 01:59 PM
