edge comp , hardly makes a difference on max!
Old Jun 26, 2013 | 09:56 PM
guimond47's Avatar
Default edge comp , hardly makes a difference on max!
hey , i just installed my edge comp on my 98.5 cummins. the install went well smoothly. but results werent so impresive.
i held the button and realease to make the leds on the box flash and cranked that up and the regular dial cranked up so 5x5 settting.
i have the stock lift pump still and on 5x5 wot, psi dint go under 11psi. and max boost see was 26.....:S theres gotta be something wrong here, its a stock truck with an hx35/40 turbo. stock injectors too , it smoked but not ALOT.....
got the wire tap on the pump hooked up to ... can some one fill me in ..
got a raptor 150 and 125hp DAP injectors on the way. i shoulda spoooled up more boost then that.... even tho the trucks currently stock with a pprogrammer maxed out..
tested the grey wire at the tap , but tested it at the edge box connector and no voltage with key on engine off. wire tape must be garbage,....
Old Jun 27, 2013 | 02:15 AM
H.R.D's Avatar
Sounds like it is not tapped correctly to me.
Need to look into getting a stealth plate cover.
Old Jun 27, 2013 | 07:13 AM
guimond47's Avatar
Only getting 1 volt at my modual from my wire tap.
Old Jun 27, 2013 | 09:01 PM
BarryB's Avatar
what is the voltage supposed to be?
Old Jun 28, 2013 | 04:15 PM
guimond47's Avatar
12v . Figuered put i tapped the wrong wire:p
Old Jun 28, 2013 | 04:44 PM
BarryB's Avatar
reason I ask, I have a stealth plate on mine , I don't have much coming from my edge comp. gunna check my voltage, make sure its getting the correct voltage.
Old Jul 1, 2013 | 10:09 AM
guimond47's Avatar
Ohh key on engine off 12 volts at wire tap
Old Jul 1, 2013 | 05:08 PM
BarryB's Avatar
Thanks I'll check that out.
RexShoppe
Price Quote - Request A Price
Nov 23, 2015 02:38 PM
Rusted Dragon
Feb 27, 2015 09:46 PM
scottxmorris
Feb 6, 2015 05:33 AM
FF131
Jan 21, 2015 11:37 AM
scottxmorris
Dec 31, 2014 03:20 PM
