04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
Loosing Prime????
Old Jun 26, 2013 | 09:04 PM
dprince03's Avatar
Default Loosing Prime????
Im new to this site looks pretty bada$$. just wondering if anyone has had trouble loosing prime on fuel system. I have a 04.5 GMC Duramax. Any suggestions????
Old Jun 28, 2013 | 01:45 AM
2004LB7's Avatar
common issue.
first place i would look is the bleed screw on the filter housing, they will often look ok but leak air past it. the O rings on the primer bulb some times leak too. there are filter housing rebuild kits out that are fairly cheap. sometimes it is the hoses after the filter that get old and dry and start to leak. one last place to check is the water in filter sensor, when over tightened it can crack.
mesjr
Sep 29, 2015 06:43 AM
NSmachine44
Aug 16, 2015 09:25 PM
Baradium
Mar 9, 2015 07:15 PM
