Click no go
Old Jun 3, 2013 | 12:23 PM
cookiemonsterblue's Avatar
Default Click no go
You know you have a problem when Dodge can't tell you. I have a 98 Dodge 3500 5.9l 12 valve, drivers side main battery has several hot leads that come off it. One of the leads(black on mine) comes off a single eyelet and splits into 2 fusable link 8 gauge wires and runs directly below battery box to a ...(looks like a solenoid but isn't). What is this part. I used to have a manual that has disappeared. Dodge doesn't have it in any diagram(they asked me to bring the part in for identification).
The reason I am trying to identify it is when I turn the ignition on I get a hard click noise from this area, I believe it is interrupting the signal to my starter(brand new just replaced). This truck drove into the barn 3 years ago and got parked, for maintenance. I am now trying to get it started.
Old Jun 3, 2013 | 12:38 PM
MillerBoyzDiesel's Avatar
You sure that its not the intake heater relay?
Old Jun 3, 2013 | 12:44 PM
no i am not i am looking that up now
so next question would that click and interupt starter?
Last edited by cookiemonsterblue; Jun 3, 2013 at 12:44 PM. Reason: Automerged Doublepost
Old Jun 3, 2013 | 01:07 PM
Does it click when you turn key on or when you try to start the truck? Can you turn the engine over with a ratchet and socket?
Old Jun 3, 2013 | 01:31 PM
clicks when I try to start truck no I haven't tried to manually jump starter since I replaced it
Old Jun 3, 2013 | 02:16 PM
Im askin if the engine turns over free by hand to make sure its not locked up. The batteries are good too right?
Old Jun 3, 2013 | 08:37 PM
Sorry I have been at the barn experimenting. Here is the update, engines starts and runs smoothly by jumping starter. However trying to use the key results in just a click. Checked all the fuses they all are good. Weird thing is my windows won't roll down by switch either. I am gonna wait a bit and retest all the fuses again. I am also going to try an find a diagram for the power center under the hood(the cover which has that came up missing also) I need that diagram to figure out which relay is for starter. Any input you can give me to figure out my starter issue would be grand.
it was a maxifuse. but i found new problems
Last edited by cookiemonsterblue; Jun 3, 2013 at 08:37 PM. Reason: Automerged Doublepost
blackbessie
Apr 2, 2015 10:25 PM
