Head Gasket(s) Or Cracked Head????
Old Mar 31, 2008 | 08:31 PM
wildbill's Avatar
Question Head Gasket(s) Or Cracked Head????
Ok, just found out from my dad that 2 months prior to getting the transfer case in that the engine was locked up from coolant. I got the t/c in a couple weeks ago and it was smoking (white) for 8 blocks before it cleared. I haven't dropped the drain plug to check for coolant contamination. TIA! If it is cracked head(s), could a guy still get a complete remand 6.2L? I got sick when he said 454 or 350.
Old Apr 4, 2008 | 12:15 AM
bigcountrysg's Avatar
Yes you could get reman heads for it. If it is in deed the heads are cracked or bad. But I would be looking at the headgaskets first.
Old Apr 7, 2008 | 03:37 PM
LOGANSTANFORTH's Avatar
if the gaskets are bad and the heads arent leaking water, just put the cracked heads back bon with new gaskets......i know, i know, trust me, its not the first time ive done it, just did a set about 3 weeks ago......
Old Apr 7, 2008 | 07:07 PM
wildbill's Avatar
Fired it up a few days ago, then again yesterday. Both time had a bad miss, with white smoke that smelled like fuel, coming out the pass. side exhaust.
Old Jun 29, 2008 | 01:58 PM
wildbill's Avatar
Finally got the cylinder heads off and found this on the drivers side head, #1 cyl. I hope it isn't a crack.
Old Jul 7, 2008 | 10:47 PM
wildbill's Avatar
Almost got it back together. Got a bunch of lines and brackets to figure out.
Aside from it popping from the intake, no headlights, it runs smooth and no antifreeze blowing out the radiator.
Old Jul 19, 2008 | 12:42 AM
wildbill's Avatar
Problem fixed. Thanks!
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
Hardcorefx4
Oct 6, 2014 07:47 PM
