trans pressure adjustments
Old May 20, 2013 | 03:39 PM
4x4manonbroke's Avatar
Default trans pressure adjustments
Im wondering where to source the line pressure so i can check my line pressures after i install my new converter .... and with a low stall converter whatthose pressures should be ?
Old May 21, 2013 | 03:48 AM
97cummins's Avatar
john,did you get the text i sent you. I have a book for your tranny.
and i know where to hook your gauge up at.
Old May 22, 2013 | 02:12 PM
yes i got the text .... a bit late but i got it .....
antone else got it that can explain it in quick lamens terms ?
Old May 28, 2013 | 12:53 AM
97cummins's Avatar
how you liken your new torque convertor john
Old May 28, 2013 | 08:20 PM
Scott Redden's Avatar
i just had a dual disk and valvebody installed and am kinda curious about the pressure my self.
Old May 28, 2013 | 08:29 PM
ok so I like to new conv. ..... on that note she still shifts not so good .... waiting too long to shift into 3rd and then into OD/ lock up ....... it seems to like to shift near 2700-2850 for some reason .....
we ( me and 97 Cummins ) adjusted the smaller allen head 2 turns out , and no other adjustments .... the 1-2 shift is firm and the 2-3 shift is better ... but all in all she needs to shift at lower RPM's ..... shift kit maybe ? ... I dont beleive I nee an entire valve body to solve this issue ...I have bombed many 727 toqrue flight transmissions with just a shoift kit but not sure if the pressures would work the exact same or gimmie the same results ???
any one know ?? with out spending more than 200 bucks I should be able to make it shift better I think... maybe
Old May 29, 2013 | 05:26 AM
97cummins's Avatar
We need to figure out what pressures your at when your transmission is shifting.
Or you should call and talk to chuck at the power shop and see what he says.
Old May 29, 2013 | 07:15 AM
cummins937's Avatar
Have you tried adjusting your tv cable? Mine was shifting very light and early, so I adjusted it about 1/4" and it after that it would hurt your neck and shift at about 2500rpm WOT. I had to move it back some...it only takes a very small adjustment to make a big difference.
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
veggyoilkid
Nov 10, 2014 12:39 PM
