6.5 turbo
Old May 16, 2013 | 07:29 AM
lefty259's Avatar
Default 6.5 turbo
I have a 1998 silverado 3500 with a 6.5 turbo. I run a wvo kit in it and have had to replace a few ip's. I believe that I may have other issues with the truck. It coughs black smoke and hitches/loses power under load. I ran a scan for codes and came up with these...
p0113
p0216
p0238
p1214
p1218
After reading some similar posts in the forum, I decided to check the vaccum to my actuater- there is none!
I cleared the codes and did a key on,key off reset of the injection pump timing, and took it for a run. It runs a bit better, but still came up with the code p1218. These last two codes are not in my code book.
plz help
these issues are running on diesel- it wont run on veg
Old May 16, 2013 | 06:03 PM
j johnson's Avatar
the p1218 you refer to is injection pump calibration circuit..might want to do a google search and see if there is any more info....scott
the p1214 is injection pump timing offset..hope this helps...
Old May 17, 2013 | 04:29 AM
lefty259's Avatar
I will put another Pmd on it. I have a spare
Old May 22, 2013 | 08:04 AM
lefty259's Avatar
tried a new pmd but still the same. Its starting real hard now
Brclouse
Nov 18, 2015 08:44 AM
Grey Rhino
Aug 12, 2015 06:47 AM
klein444
Feb 27, 2015 01:53 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
Snoobly
Dec 11, 2014 11:59 AM
