oil coming out of dipstick
Old May 2, 2013 | 01:44 AM
cummins_spool_spinner's Avatar
Default oil coming out of dipstick
I have a highly modified 95 reg cab (havent been on here for a while). Checked breather tube and no air is coming out pretty sure its clogged, i know this is a common issue. However im not sure if the rings are bad or not...i dont want to put money into the CASE IH 2 way valve covers if i need an engine overhaul.....oil comes out light but continuous under acceleration none at idle if that helps any ideas, thoughts or imput would be greatly appreciated.
Old May 2, 2013 | 04:23 AM
97cummins's Avatar
I would pull the breather tube off to see if it's plugged like you said,and if it is ,unplug it. It may be over pressureising the system and trying to releave the pressure.
Old May 2, 2013 | 11:51 AM
Seth'sCummins's Avatar
If you can modify one of your valve covers so you can clamp on a little filter to help it breath if you do not unplug the tube.
Old May 3, 2013 | 08:18 PM
4x4manonbroke's Avatar
Sounds like you might have a turbo seal problem ..... You can apply regulated air to inlet with the outlet plugged off ... ( about 30 psi max I believe ) and you should not hear any air coming out of either end of the turbo ... if you do you need a re bushing kit for your turbo...
lacrab
Sep 10, 2015 01:17 AM
|WYG|SS
Aug 19, 2015 10:53 AM
soco
Jul 27, 2015 06:06 PM
Jake12valve
May 10, 2015 11:57 PM
ramrunner01
Apr 25, 2015 10:11 PM
