what is the cost to build a fummins
Old Apr 23, 2013 | 01:19 PM
makeitsmoke's Avatar
Default what is the cost to build a fummins
The 99+ f250 swb 4door is still my favorite body style so iwant to put cummins in one i want to use 12v 47rh and any other of drive train i can has any one done this? What is the cost? I see alot of swaps useing ford drive trainwith cummins i have horrable luck with ford trans seems like a simple swap what is y'all s experince
Old Apr 23, 2013 | 03:49 PM
93_Fummins's Avatar
Nobody can put an exact cost on it because it highly depends on how much work you do yourself and how much you can source all of the parts for...
Old Apr 24, 2013 | 10:55 AM
cummins_ford's Avatar
i bought a f250 rolling chasis, zf5, southbend clutch and flaxplate, a motor, motor mounts, exhaust manifold for about 5000-5500 and the motors not in the truck yet, i still need the adapter plate and a turbo, once i have those two items i can put the whole drive train actrually in the truck, then the fun of getting lines made for ac power steering and getting radiator hoses and such, i sent my harness out to dieselconvertions on the fifth of this month but still havnt heard back from them, the swaps allot more stright forward then i thought after starting it and actrually reading about them and the parts.... you can actrually buy the majority of the parts online with out making much custom stuff.... i have been having allot more luck with www.dieselconvertions.com rather then everyones favorite Destroked - THE Cummins Conversion Company : Home Page everything from talking on the phone to the website i like more,
Old Apr 24, 2013 | 11:20 AM
I wanting to use the whole drive train out of the dodge i have a dodge now that ive taken the computer out of so i wont be use one in my fummins either seems like just motor and trans mounts power stering hoses and i dont know about the front end think im going to try and use the dodge front axle what about a ford body on dodge frame?
Old Apr 24, 2013 | 11:46 AM
93_Fummins's Avatar
Originally Posted by cummins_ford
.... you can actrually buy the majority of the parts online with out making much custom stuff.... i have been having allot more luck with dieselconversions.com rather then everyones favorite Destroked - THE Cummins Conversion Company : Home Page everything from talking on the phone to the website i like more,
Looks like dieselconversions.com is the new face of ford-cummins.com....haven't seen the new site until now, but it does look like an improvement. I've dealt with ford-cummins.com in the past and they are pretty fair; fast turnaround and decent customer service, but some of their parts just don't seem very "refined", imho. Maybe things have changed in the past 5 years...
I'd steer clear of the Dodge front axle personally....unless your Ford happens to be 2wd and that's all you have to work with. I'd mainly avoid the Dodge axle due to balljoint life reputation, CAD, and non-freespin unit bearings....not to mention the pain of having to adapt or convert all the short link and coil stuff. The Fords are straightforward axles, non-CAD, simple leaf or radius arm suspension, and most have dialouts....and if it's already under the body you like, why not keep it simple?
Body swaps can be a pain seeing as all the mounts are likely fairly different between the two. It can be done, but I really see no benefit in doing one versus bolting up the Cummins in the Ford engine bay.
Last edited by 93_Fummins; Apr 24, 2013 at 11:46 AM. Reason: Automerged Doublepost
Old Apr 24, 2013 | 01:02 PM
im with you, the whole point in even doing the swap in my eyes is to get the good motor but get rid of the bad chasis, its almost like your doing to much work to come out of it with litterally pretty much the same truck just different interior..
Old May 1, 2013 | 01:56 PM
Rooster438's Avatar
I have a great start for someone willing to put the finishes on one. I have a 2005 F-250 with all the adapter plates and everything installed. I was only lacking the TPS and the Power steering stuff. I was forced into driving it and the Transmission went. I would gladly take $6500 for the truck. Located near Memphis Tn.
Old May 10, 2013 | 09:57 AM
smogmonster's Avatar
i like the idea of this swap myself but whats the deal with dmv or smog if i move back to ca
and i have a diesel motor in a gas or diesel newer truck???
should i just register it in another state where i live first??
what body style is this truck any pics? auto? manual? i can send u my email if that helps
Last edited by smogmonster; May 10, 2013 at 09:57 AM. Reason: Automerged Doublepost
redveloce
38
Jan 22, 2017 03:55 PM
DODGEARMYGUY
Feb 8, 2015 07:08 PM
jtwthaxj
Jan 14, 2015 06:52 AM
Nov 16, 2014 05:14 AM
Oct 15, 2014 12:30 AM
