Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
PA trailer tow question.
Old Apr 23, 2013 | 07:03 AM
acblair801's Avatar
Default PA trailer tow question.
I currently own a 2001 f250 diesel. Crew cab short bed with a 6 speed. Just purchased a tractor backhoe that weighs in at 8000 lbs so its time to upgrade to a bigger trailer. Not sure what PA law requires and I'm hoping some one here will know. 12000 lbs total tractor and trailer I would assume. My bumper hitch says 1000 tongue weight and 10000 tow. Weight distribution I can do 1700 tongue and 14000 tow. Do you think I would be legal? Thank you.
This isn't a business and won't be towed everyday. Just for family or friends to help out or make a couple bucks once in a while.
Last edited by acblair801; Apr 23, 2013 at 07:03 AM. Reason: Automerged Doublepost
Old Apr 24, 2013 | 04:20 AM
97cummins's Avatar
You should post this question in the social group section for your state. Someone else may be able to help you with this question.
Old Apr 24, 2013 | 06:28 AM
acblair801's Avatar
Where would that be?
Old Apr 24, 2013 | 08:33 AM
daveO's Avatar
Okay, I'll try to answer this the best I can. As far as license is concerned, as long as your total combination weight is below 26,000, you can drive legally on a class C. If your truck is registered as a combination vehicle (probably not), you must be registered for the combination weight of truck, trailer, and load. If not, if you were stopped, they would check the weight of the truck and trailer/load separately. You can not exceed max weight of your registration on both truck and trailer, and vehicle's max axle ratings.
Old Aug 10, 2013 | 10:59 PM
bowietrucking's Avatar
wrong. if you are hauling commercial, if your gvw rating on your trailer is over 10,000 lbs (meaning 10,001 lbs and greater, you MUST have a class a cdl.
Old Aug 17, 2013 | 05:33 PM
codyawise's Avatar
When you decide to upgrade your trailer take a look at us at bwise trailers. We'll hook ya up to meet your needs. As far as laws I'm not 100% sure on that myself
Old Aug 17, 2013 | 09:46 PM
daveO's Avatar
This is true, but the OP said he wasn't going to be towing commercially, just for friends/family.
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
May 7, 2015 11:50 AM
May 7, 2015 01:40 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
