straight pipe while pulling travel trailer
Old Apr 16, 2013 | 06:56 AM
Joejo7883's Avatar
Default straight pipe while pulling travel trailer
I am a fairly new diesel owner I have an 06 Ram 3500 Mega Cab 4x4 SRW. Ive had the truck about 3 months now, its a 4" exhaust but it came with a Banks muffler and 5"tip. About a month ago I had the CAT removed but left the Banks muffler on I heard no difference in sound hardly and noticed a 1-2mpg inc. which was good. I also removed the silencer ring as well. However I'm thinking the sound I'm looking for will require the muffler to be removed. On that note I also pull a 34' single slide out bumper pull travel trailer weighs about 6k lbs. Does anyone have any thoughts as to whether I should go ahead and remove the muffler? I'm not too worried about the outside noise as I am the inside. Any and all thoughts would be greatly appreciated.
Old Apr 16, 2013 | 01:04 PM
avolnek's Avatar
I am set up in a very similar fashion to you. I bought mine roughly 3 month ago! 2006 2500 with 4" turbo back with no cat or muffler but it had a turn down in front of the rear axle. I love the sound but the drone from the exhaust off the camper once hooked up has gotten annoying already and I will be looking for a tail pipe. So if anyone has any suggestions where to find one shout! But as far as the sound, I love the sound!!
Old Apr 16, 2013 | 09:13 PM
5.9Cumminsturbodiesel's Avatar
my uncle has 98 ish cummins dulley stright piped he pulls a 5th wheel toy box, his has like 6"-7" tip on but has it out past the trailer so you don't get to much drone from the trailer being there but the side of the trailer is black after come cross country with it but it only little but of coal !
Old Apr 16, 2013 | 09:25 PM
ezoliver's Avatar
Even with a tailpipe you will probably still have the drone when towing...
Old Apr 17, 2013 | 08:36 AM
avolnek's Avatar
I would expect to have some drone, but do you think it would be less with a tail pipe out the side than blowing it straight at the ground and then having the camper scoop it up?
Old Apr 17, 2013 | 09:25 AM
ezoliver's Avatar
Maybe a little less but most of the drone is from the actual pipe under the cab / bed resonating due to being just a pipe with no cat, muffler or resonator on there.
Any one of these added into the middle of the pipe will help drop the resonant noise emitted into the surrounding metals (cab)
Old Apr 30, 2013 | 11:06 PM
sthrnrider's Avatar
Yeah what he said^^^^ get a resonator put on right after your down pipe will kill a lot of that in cab noise
PowerstrokeDepew
99-03 7.3L Performance
May 5, 2016 08:12 PM
Blake35
Jul 25, 2015 03:44 PM
RAtwood
Apr 12, 2015 08:56 PM
Josh042788
Diesel Engine Conversions
Dec 23, 2014 09:42 PM
