99 24v to 97 12v swap?
Old Apr 11, 2013 | 09:53 PM
duckslayer31's Avatar
Default 99 24v to 97 12v swap?
ive got a 99 24v 4x4 automatic transmission with 355 gears. im looking to swap a 97 12v motor and automatic trans into it! do i need to get a different transfer case and what do i need to do this? how hard would it be?
Old Apr 11, 2013 | 10:44 PM
RanchhandTCR's Avatar
If they are the same trannies then your should be ok with the transfer case.
Are you going to use the same PCM? and to do it is simple to pull the T Case just takes some grunting and cussing and making sure you dont hurt your self. A good engine hoiste would be nice. I would take the entire front end off such as the front clip, hood, and radiator, tranny cooler, and intercooler off so you can slide the engine in rather than play the squezzing it in game.
Last edited by RanchhandTCR; Apr 11, 2013 at 10:44 PM. Reason: Automerged Doublepost
Old Apr 12, 2013 | 06:17 AM
Could I use the pcm off my 99? And are the drive shafts the same? And what would I do for electrical?
Old Apr 13, 2013 | 10:19 PM
No the pcm is not the same for the 97 since the 99 is talking to a 99 Cummins ECM and is only programmed for that communications with those moduels on your truck, Im not sure if the yoke size on the tranny of a 97 is smaller than the one on the 99 that would be easy to check on you own. As for electrical thats the fun part not completly sure what you would have to do, never done a swap always just a replace.
Question to ask is why are you wanting to swap your ISB 24 Valve for a B series 12 Valve?
Last edited by RanchhandTCR; Apr 13, 2013 at 10:19 PM. Reason: Automerged Doublepost
Old Apr 18, 2013 | 07:51 PM
kapnhook's Avatar
why?alot of work and for what gain?
savage-rider
Diesel Engine Conversions
Sep 26, 2015 12:43 PM
otpracer
Sep 18, 2015 02:31 PM
Dayt the great
Aug 16, 2015 07:42 PM
Murdock
Apr 12, 2015 06:16 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
