cat in place of cummins
Old Apr 7, 2013 | 07:17 PM
thetowguy's Avatar
Default cat in place of cummins
hi everyone i have a 2000 freightliner fl60 with a 5.9 cummins in it the engine has 350k and has a ton of blowby and leaks oil out of the vent tube. i also have a 1995 chevy with a cat 3116 in it and a 6spd trans just wondering if i can put the complete cat motor and trans with the harness and and ecu inthe freightliner and what else i might have to replace to make it work.
thanks
Old Apr 7, 2013 | 07:29 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
have you ever thought about rebuilding the 5.9.
Old Apr 7, 2013 | 07:40 PM
thetowguy's Avatar
Default swap
yeah priced it out but its gonna cost more than i have to spend right now but since i have the other truck just sitting around with a bad rame thought it might work
Old Apr 7, 2013 | 08:36 PM
wyoranch's Avatar
3116 is mechanical injection and wont need a computer to run. If its electronic its a 3126
And have you looked around for a used Cummins? they can be.had around where I live for pretty cheap, 1500 will buy a good running motor around here
Old Apr 7, 2013 | 09:01 PM
thetowguy's Avatar
Yeah I priced some out the 24v 5.9 goes for 3 grand and up around here
Old Apr 8, 2013 | 07:14 AM
wyoranch's Avatar
Yeah, they're pretty high here too. But you can find ve pump motors cheap and with a little tuning they'll outpull a stock 24 valve. That being said, I had a 91 topkick with a 3116 and.it was a good motor, comparable to a 5.9. It was a dog but I turned up the fuel rack and it woke.up big time
Old Apr 8, 2013 | 07:30 PM
thetowguy's Avatar
how do you crank up th fuel to get more power out of it and can yo also do that o a 3126. i have ne in my chevy 6500
Old Apr 8, 2013 | 07:48 PM
wyoranch's Avatar
The 3126 is electronic and I don't know.if.they make.chips for.it or not. On the 3116 you pull the valvecover and adjust the travel on the fuel rack. Don't remember exactly how, I looked it up online. Did it years ago.
Old Apr 9, 2013 | 08:22 AM
93_Fummins's Avatar
Diablo and TS Performance both make "juice boxes" for the '98-'00 3126 CAT...30% power increase, iirc...
Old Apr 9, 2013 | 07:27 PM
wyoranch's Avatar
His is a 95. Maybe its a 3116 after all...
JoeyMiR
9
Feb 3, 2018 10:05 PM
Shun70
Sep 21, 2015 01:39 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
